14 Jun 2023
Advanced options for managing attachments with eM Client
Sometimes, you only need to see the file - not the message. Trying to figure out which email has the correct file attachment can be a pain if your inbox is flooded with multiple emails from the same person that all include attachments. Our options for managing attachments are essential for both your personal and professional email accounts. Manage attachments from your emails, calendars, contacts, tasks, and notes with eM Client. We decided to make the process easy so you can find the files you need in only a matter of seconds.
eM Client all attachments
Options for managing attachments using eM Client
You’ve got plenty of options for managing attachments using eM Client. The best option depends on the quantity of attachments you need to view at once and whether or not you know the specific sender of the attachment. View attachments through individual emails or use Contact Details to view all of the attachments received from a sender.
To manage attachments in an individual email:
  • Select the email that includes the attachment you wish to view.
  • Click on the attachment and a pop-up window will appear asking if you’d like to Open or Save the attachment to your computer.
  • If you select Save, a window will appear asking you to save your file in a specific folder of your choice on your computer.
  • If you select Open, the attachment will simply open in a new window using the default application for the file type on your device. This allows you to review the document before saving it.
To manage attachments from Contact Details:
  • Select an email from a specific contact. It can be any email; regardless of whether or not the selected email has an attachment.
  • After the email has been selected, a panel labeled Contact Details will appear on the right side of your screen. This panel includes information about the sender; including your message history and attachments sent to you from the sender.
  • Next to History, select Attachments.
  • You can preview the attachment by simply hovering over it with your mouse. Once you’ve found the desired attachment: click Open or Save.
The Contact Details option for accessing attachments from a specific sender makes the process easy if you’re trying to quickly access documents from someone with a long history of sending you attachments. It’s much easier than using the search bar or scrolling endlessly to find the attachments you need. You can view the attachment history in the Contacts section using the attachment tab in the People view. This will also let you view your attachment history between you and the sender!
How to use All Attachments View with eM Client PRO
eM Client users get the added bonus of accessing the All Attachments view with eM Client Pro! All Attachments view is a revolutionary feature for managing email, calendar, task, and notes attachments. Your attachments are displayed together without the original email messages; making it simpler for times when you only need the attachment and not the message. All Attachments View allows you to see all attachments from all senders - all in one place.
To access the Attachments View, click on the More button (three dots) at the bottom of the screen on the left panel. Here’s how to get the most out of All Attachments View:
  • You can view all of the attachments you’ve ever received in either a list or a card view if you select All in the toolbar.
  • Looking for a specific file type? Select Images, Media, or Documents to narrow down your search. Archives contain .zip, .rar and similar file types containing more files inside.
  • Sort your files based on the date they were sent. Click on Created to reorganize your documents based on if they were sent recently or a long time ago.
  • After finding the attachment you want, select it. Look at the toolbar to see your options. You can either respond to the sender using Open Source, save the attachment using Save as, or you can Forward or Delete the attachment.
  • If you choose Open Source: a new window will appear showing you the original message, event, task, note or contact the file was received or saved in. You can interact with the original source of the file this way, if you for example need to update some details or respond to the message.
  • If you only need to forward the file to another sender - select Forward in the toolbar. Your attachment will be automatically included in the forwarded message that appears in a new window. Add the name of your recipient, type your message, and then your attachment is ready to go!
Once you’ve tried All Attachments View, you’ll have a hard time living without it. This user-friendly feature will save you time and energy. All Attachments view is just one of many innovative features that make eM Client the best email management app for everyone. If you want to learn more about all of the benefits of eM Client Pro License, check out the list on our pricing page. To find out about updates and how to get the most out of eM Client - read our blog!
New to eM Client?
  • unlimited email accounts
  • unlimited commercial use
  • professional VIP support
  • Snooze Email
  • Mass Mail
  • Send Email Later
  • Watch for Replies
    and more.
